Surpass Hobby TS160 Brushless ESC >
Like Tree17Likes
    Hide Wikipost
Old 06-10-2022, 12:58 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Surpass Hobby TS160 Brushless ESC
Last edit by: lexusbest
Edit date: 04-15-2022
Product Specifications:
Brand: Rocket
Item Number: TS160V2
Continuous Current : 160A
Peak Current: 760A
Forward /Brake /Reverse : YES
Dimensions : 38.2 (L) *30.6 (W) *32 (H)
oltage Input: - 4.8V-9.9V
Net weight : 54G
Gross weight : 149G
B.E.C : 3A 6V/7.2V
Motor Limit: Over 4.5Turns
Motor type : 540 sensored size brushless motor
BEC.: 3A 6V/7.2V
Multi Protection System: Yes
Package listing:
1 x Rocket Turbo TS160V2 Brushless ESC
Print Wikipost
Old 11-11-2020, 05:19 AM
lexusbest's Avatar
Default Surpass Hobby TS160 Brushless ESC
Hi there!
Surpass Hobby recently released an update for their TS160 PRO ESC, which is now called as TS160V2 PRO.
It comes with a separate programming port that I found very interesting over unplugging the esc itself or fan ports
Brand: Rocket
Peak Current: 760A
Net weight : 54G
Gross weight : 149G
B.E.C : 3A 6V/7.2V
BEC.: 3A 6V/7.2V
Package listing:
I'm likely to try one of these escs at a price point of around 100$ and filling this thread with more useful info.
If you have any comments i would be happy to hear
lexusbest is offline
Old 11-11-2020, 08:05 AM
OffRoadJunkie's Avatar
Originally Posted by lexusbest
Hi there!
Brand: Rocket
Peak Current: 760A
Net weight : 54G
Gross weight : 149G
B.E.C : 3A 6V/7.2V
BEC.: 3A 6V/7.2V
Package listing:
WOW... You would think they would try not to make it look too much like a Hobbywing. Even the programmer. So, is it true that Hobbywing and Surpass ESCs come out of the same factory?
OffRoadJunkie is offline
Old 11-11-2020, 09:34 AM
lexusbest's Avatar
HW motors are definitely not made by surpass manufacturer, but like you said escs are pretty similar. Once i saw surpass esc programming options somewhere. Is was close, if not exactly the same programming that HW has, including brake frequency, slope and thing like that seen on HW software.
I have been searching for a while but i didn't find any manual or software to download.
Surpass motors are top quality and performers. Hope someone come with some more info about these great looking escs
Old 11-11-2020, 10:08 AM
I haven't had a chance to try out their motors, but I heard they were top notch. Makes me believe their ESCs will perform the same.
Old 11-12-2020, 07:58 PM
I had a surpass esc. Till it burned up.. Definitely not hobbywing, at least not the one I had.
BlairW is offline
Old 11-22-2020, 03:34 PM
frewster's Avatar
Most of the Surpass ESCs are made by ZTW, just like the Dash, Reds, Fantom, HobbyStar, etc ESCs.
Funkymojo and gigaplex like this.
frewster is offline
Old 11-25-2020, 05:11 AM
Default Interesting
Notify us if u find this esc worth it.. i was considering between this esc & HW XR10 pro.. since this is cheaper, i might lean towards this.. but i can’t find any review on it yet..
aliffnajmi93 is offline
Old 11-25-2020, 01:07 PM
lexusbest's Avatar
It would be great to have a manual or programming software. But no answer from surpass yet
Old 01-09-2021, 10:52 PM
Can anyone tell me how to set throttle end points I don't have a manual for this esc. Or a link to a manual for it I've searched Google for a couple of hours with no luck
Danton88 is offline
Old 01-09-2021, 11:43 PM
frewster's Avatar
Try this: https://www.manualslib.com/manual/16...-Pro-120a.html
frewster is offline
Old 01-10-2021, 07:38 AM
Originally Posted by frewster
That helpes a bunch thanks
Danton88 is offline
Old 01-10-2021, 06:46 PM
Chris916's Avatar
lexusbest likes this.
Chris916 is offline
Old 01-15-2021, 06:44 PM
I have another question with the ts pro 160. Does anyone know what type of connector is used for the 3 wire Progam/ fan plug on the V1 esc?
Danton88 is offline
Old 01-15-2021, 09:23 PM
it is a nice esc. the last page talks about using the program card as a usb adapter and programming with your pc. Do you guys know if that is possible?
mrmad is offline
Old 01-17-2021, 11:03 PM
lexusbest's Avatar
Thanks to Chris916 for sharing the manual. Looks very similar to HW ESCs. We are left programming software and firmware update log
